Hey guys,
Just putting this expression of interest out there for a long block.
The engine was built by Advan Performance Centre in NSW and was a no expense spared build.
The engine is a 1996 S2 RB25 and was rebuilt with the following specifications:
BLOCK
- R34 GTR N1 crankshaft to bring engine capacity to 2.6L
- H beam Carillo connecting rods
- Mahle forged pistons
- N1 Oil pump
- N1 Water pump
- ACL Pro Series bearings
- New welsh plugs, gaskets etc. done during build
HEAD
- HKS metal headgasket
- HKS 264 degree intake and exhaust camshafts with VCT removed
- HKS Cam gears
- HKS Valve Springs
- HKS Timing Belt
- New seals, guides, valves etc. done during build
- Oil restrictors
- ARP Head Studs
- Machining, porting and polishing all carried out by Advan Performance Centre
This is a big HP engine built to withstand the 700HP and 8000RPM limiter is runs all day long. Engine has now done just under 20,000km and is healthy as ever. Only ever run on Motul Chrono 10W40.
* Currently the car is making between 360-390rwkw on BP98 on 1.5-1.6BAR of boost pressure through a GT3540R in a R33 GTST. The car is an absolute animal when it comes on and is a real handful to keep straight.
The engine is still in the vehicle so can be test driven if required. I'm hoping not to pull the motor out until I have a buyer interested but will see how I go.
Asking $8000 for the long block but I am open to reasonable offers if the price doesn't seem fair.
If some one wanted the complete engine setup with manifolds, turbo etc. I would be open to discuss that as well.
The car has run a low 11 second pass with this package in street trim on a shitty track. Put the engine into a VL or a S chassis and you have a 10 second car.
Any one that has done an engine build like this through a well known workshop knows how much money gets put into these builds and the brand new parts alone are worth more than what I'm asking for the engine so I think it is fair.
If there is any more info I can think of I will update the thread. Just quickly writing it up so I may have missed something!
Thanks guys.
Phil
Will give a free bump as well. Seen this package in its early days after build and it sounded like a f**king mental angry chainsaw on crack! Would be a perfect buy for someone looking to save a few dollars
Edited by Weapon
Engine is two years old and has done approx 18,000km. Didn't keep any receipts unfortunately.
I'm planning on dropping the sump off and taking photos of the crank, rods and pistons though to show proof of the internals.
If some one just wanted the bottom end I will seperate if need be.
Won't seperate the head until I have a buyer for the bottom end though as the head/cams will be quite easy to sell.
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
