I'm thinking that I'd rather have some comfort from my 34, heading away from squeaky brakes and blown pipes and gaskets.
I'm thinking about a 180 or an old silvia or something. Not really sure.
Should I bother importing something at this end of the scale or buy local?
What do people think?
This whole 15 year rule gives me some possibilities I guess.
I want to do track work and go to drift days and the like.
https://www.sau.com.au/forums/topic/43655-opinions-on-cheap-car-to-race/
Adam, definately buy something cheap to race....I wish I had asked myself the question before I took my road car on so many track days
$10k landed in Aus is any car up to 400,000yen, and that includes r32 gtrs, rx7, gtst, 180sx etc etc
Well cant u just import cars to race? IE not comply them or anything?
If so then get a 32GTR
You can, but I've seen cars to be imported for race that require a minimun of a CAMS C3 racing license to be able to import it.
I could be wrong.
I know it aint no Jap import, but i know of a VL with 9" cambered diff, Sparco race seats, Alcon Brakes and rotors, Cams approved roll cage and log book, plus other bits and pieces ebing sold as a roller for $6,000, i was thinking about throwing my running gear into it and having a kick ass circuit car
I'm not sure how serious I want to race so I'm guessing I'll have to road register it. I'm thinking that a GTR could cost some bigger $ to keep happy whereas something smaller with only one turbo might stay within a modest budget.
Would it be easy to get something already modified or would I have compliance issues?
Yeah GTR can get expensive, the other thing you need to think of is what the hell will you fit in with a helmet on :P the 32's a close fit for me, I think you will have heaps of trouble with an S13.
And I'm sure there are ppl around with C3 that can help with the import...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
