Hey guys, im in the middle of relocating my fuse box from the engine bay to under my dash, i cut all the wires running into the fuse box. Started hooking them all back up and found there are 3 wires exactly the sam color green/white. Does anyone know if i can just put them together or have to try the right wire? Imagining since they are all the same color they would be the same thing wouldnt it??
https://www.sau.com.au/forums/topic/436555-what-are-these-wires-for/
Not spare wires, i had cut them when taking the fuse box out. Didnt reaslise there were 3 the same color otherwise would have marked them. And yeah tried tracing them and they go into this plug board thing behind your drivers kick panel
