Hey,
Last night when i was installing my ebc, i had the 2 inside lights on and i forgot to turn them off :D So this morning i woke up to my car alarm system going off, i ran to the car and try to unlock the door but it wasnt working, then i saw that the blue which wasnt flashing, so i unlock the door using the key and try to start the car nothing turn on :( no light nothing then i saw the 2 lights switch on the inside on.... NO!!!!
Anyway im going to try and jump start the car 2night, but i really need my car 2morrow i have an exam, can anyone requirment a place to go to get a new battery and what type? In the magla area would be the best thanks
Mike
https://www.sau.com.au/forums/topic/43657-my-battery-went-flat/
1 hint, dont jumpstart the car from the battery in the boot.... :(
there is points there are marked out in the engine bay with the fuses and stuff :D
Hey,
Last night when i was installing my ebc, i had the 2 inside lights on and i forgot to turn them off :( So this morning i woke up to my car alarm system going off, i ran to the car and try to unlock the door but it wasnt working, then i saw that the blue which wasnt flashing, so i unlock the door using the key and try to start the car nothing turn on :( no light nothing then i saw the 2 lights switch on the inside on.... NO!!!!
Mike
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
