Racepace offered us one already done for considerably less than that, id suggest picking up the phone and talking with them......(unsure if it was a one off built one ready to go that they wanted out the door though)
Is that rebuilt with new nearly everything or just the mod done ?
All i remember my son telling me was its was modded and ready to bolt onto a freshly rebuilt dog box we purchased from them when he was there picking it up.
Sort of made me stop for a second and weigh up the work for me to mod it Vs the price it was offered to him for.
Unsure if it was all newly rebuilt and unused, for the price it was offered for i highly doubt it. (it was that cheap)
Since the work I have been driving it for around 700Klms, still on tune in, limiter @ 5000rpm
Had the, clutch, Quaife front diff and the modified transfer case done at the same time.
When I pushed it, it feels balanced and just glides around the sharpest bend. Not sure what is doing what, trannie or Quaife as both were installed at the same time. Already had a Nismo 2-way LSD in the back (No Noise or clunking , ever ?). The new coppermix C Spec clutch is a dream :wub: felt funny as it engages very high compared to the OS Quad I had in it. Being a short arse I can move the seat back a couple of notches and get a better driving position.
I will push it a bit more once the final tune is done and the full power is on the road. I'm sure Paul could test it out and give a better run down on the Pros and Cons of the mix when he has the chance,
Even for a non racer boy, it feels good and you can notice it on a DD.
This is what they did.. Cost $1350,
UPGRADE TRANSFER CASE WITH NEW ADDITIONAL CLUTCH
PACKS .( APPROX 30% MORE CLAMP AREA )
FOUND BROKEN THRUST WASHER, BROKEN NEEDLE BEARING
AND BURNT OUT CLUTCHES AND METAL SANDWICH PLATES
WHEN UNIT WAS STRIPPED DOWN. REPLACE COMPONENTS. INCLUDING SEALS.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
