1. Nismo GT LED tail lights for R34 GTT or GTR. $1100 These are the best LED taillights for R34 - make your one stand out from all the cheapo ebay ones :D They are 2nd hand but work perfect and will look like new fitted.
2. Genuine Carbon fibre light weight GT Wing Type II. $1100 Comes with Mounts and is currently mounted to an S15 boot lid. Price will be the same whether you take the boot lid or not. Perfect for s15, but can suit any car if you make custom brackets. (MSRP USD $1800)
3. Top Secret gold edition LE37 / TE37 wheels. Rare, perfect offset for GTR. 18 x 10.5" no tyres. $3300
Pickup in Melbourne
[email protected]
LOL.... dude, I don't buy fake shit. If you want them then take them, but don't question my integrity by asking for "proof" they are genuine. They are.
Rightio mate. Thanks for the speedy response.
Wasn't questioning your integrity. Just curious because I have a set with no markings which have a couple of bulbs out. If mine weren't nismo, as an answer to my question would have verified, I would have bought yours.
Cheers.
Bump
Also selling Alcon 6-pot front and 4-pot rear brake kit, used... off my old R34. Comes with rotors and caliper brackets, ferodo ds3000 pads if anyone is interested. I will get some pics and post a new thread for them.
<br /><br /><br />I thought that was a fair question, if someone is going to buy something it pays for them to do their research. No need to get worked up about it…
Hey mates saw you had stated u had a set of alcon brakes for sale. could u let me know the specs , pics and any else i would usually ask for as well. what price were you looking at for them? also what area in Melb area you from?
What's it got to do with you? mind your own business champ. If someone did their research they would know these don't have nismo markings on them as they use the factory inner housings, especially someone who claims to already have a set.
I will take some pics when i have time and post up in a new for sale thread. The front rotors will definitely need a good machining as I was using aggressive pads on them and the car was occasionally street driven in addition to several track days, so there's some uneven wear/grooving on the rotors that should be cleaned up with machining which I might get done first before I put them up for sale.
No, it can be bolted on to any boot. At the moment the base plates that come with it are bolted on to an s15 boot lid. Can be removed if the buyer doesn't want the boot lid.
Some pics on the s15 here: http://s1116.photobucket.com/user/jdm7777/library/?sort=3&page=1
Base mount:
Example of how it looks on an R34 GTR
modp_0911_09_o%2Bnissan_skyline%2Brear_v
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
