Hi guys, I'm upgrading the turbos on my gtr and have aquired thusfar:
-700cc injectors
-2860-5s (without actuators)
-power FC
-nismo afm's
-am performance dumps
-adjustable cam gears
The turbo does not have any oil feed or drain flanges... Should I pull these of my stock turbos? If not can anyone link me to suitable place I could buy them.
Also, what else would you say that I am missing to complete the upgrade? Gaskets ect?
Appreciate the help!
Thanks
https://www.sau.com.au/forums/topic/436649-r33-gtr-turbo-upgrade/
Call GCG.
1300 887 267
They have the oil drains there. $65 IIRC. I'm not 100% sure if the stock ones are different to the Afternarket garret stuff, but the HKS drains need to be modified.
Yea, I was going to get my actuators from there. What about oil feed and restrictors? Is there anywhere in particular I should look for them?
just use the factory oil feed lines, the oil drain pipes are best ordered from gcg
Ditch the ECU all together, much better ECU's out there now. Link / Vipec, Haltech. There is nothing wrong with the old Power FC as such, its just that they are very old now and there are better options around. They still use AFM's which are fiddly at times and a MAP Sensor is hassle free in comparison. Power FC dont really offer much by way of upgrades / options. Link, Vipec, Haltech all have lots of options and accessories to add to them. Motorsports stuff, Flex fuel sensor capability, much better boost control options etc
IIRC the drains and all coolant / oil lines should work from the standard turbo's. Just get yourself a stack of new gaskets.
For gaskets try calling Powertune. They are having a moving sale at the moment and may very well have the gasket kits laying around. The kits will come with everything. Copper seals for the coolant and oil lines, new intake gaskets, new flange gaskets etc
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
