Hi guys,
I've got some stuff thats been sitting in my garage which I'm hoping to get rid of.
1. Stock 2004 Honda Accord Euro wheels. They are 16" but I'm unsure of the offset or width. I'd guesstimate around 16 x 6.5 + 45. They use the same 5x114.3 bolt pattern and same hub diameter as Nissan, so they could bolt up to a Skyline or Silvia for cheap skid wheels or if you need to pass a defect. They are in good condition, one has a small gutter rash but nothing serious. 2 dont have any tires and the other 2 have really worn out tires. I'm after $250 O.N.O. for these.
post-39984-0-35593600-1387769284_thumb.jpgpost-39984-0-89612000-1387769287_thumb.jpgpost-39984-0-15850100-1387769291_thumb.jpgpost-39984-0-02211900-1387769295_thumb.jpgpost-39984-0-53045900-1387769298_thumb.jpgpost-39984-0-83462900-1387769303_thumb.jpgpost-39984-0-38037900-1387769306_thumb.jpg
2. A whole bunch of Earls and Speedflow fittings. All work fine but some are a bit scratched from spanners.
2 x brand new Earls -10 Straight fittings. One is still in the bag, the other one is taken out but never used
1 x barely used Earls -10 Straight fitting. I think i've tested it once, but didn't fit on my setup so I never used it. Its just got a few light scratches from the spanner.
1 x used 90 degree Speedflow -10 Fitting. It's been used on my old oil cooler setup, but then I changed from a sandwich plate to one with a thermostat so this fitting no longer fitted in.
3 x pretty used Earls -10 Straight fittings. These have a fair bit of spanner markings on them. Again, they are all from my old oil cooler setups. They all work fine, just don't look that great.
My camera kinda brings out every detail in the photos, but they dont look THAT bad in real life.
After $50 FIRM for these.
post-39984-0-34695300-1387769311_thumb.jpgpost-39984-0-02163900-1387769322_thumb.jpgpost-39984-0-62190200-1387769324_thumb.jpgpost-39984-0-29098100-1387769327_thumb.jpgpost-39984-0-82139800-1387769332_thumb.jpgpost-39984-0-75212000-1387769335_thumb.jpgpost-39984-0-47335200-1387769338_thumb.jpgpost-39984-0-34504400-1387769389_thumb.jpgpost-39984-0-78817600-1387769453_thumb.jpgpost-39984-0-95303900-1387769455_thumb.jpgpost-39984-0-74223800-1387769457_thumb.jpg
3. Stock S15 intercooler. I've always kept it in case of defects, but I've since sold my S15 and have no need for it. It comes with all brackets and all of the intake piping up to the intake manifold. I'm after $150 O.N.O. for this.
post-39984-0-02591200-1387769359_thumb.jpgpost-39984-0-21758700-1387769364_thumb.jpgpost-39984-0-66430500-1387769368_thumb.jpgpost-39984-0-83846100-1387769372_thumb.jpgpost-39984-0-90578900-1387769378_thumb.jpg
4. Stock S15 Fuel Pump. It came out of a JDM manual turbo S15 which had about 80,000kms on the clock. It was working perfectly fine, only reason I took it out is so I can upgrade to a bigger pump. I'm after $60 O.N.O. for this.
5. Stock S15 boost gauge sensor. Just the sensor, I don't have the gauge. $10 FIRM for this.
post-39984-0-12306900-1387769381_thumb.jpgpost-39984-0-61173300-1387769383_thumb.jpgpost-39984-0-37467700-1387769386_thumb.jpg
I'm located in Upper Coomera on the Gold Coast, QLD and I'm happy to ship at the buyers expense.
Cheers.
Edited by Goosy
  • 4 weeks later...
  • 3 months later...
  • 3 weeks later...
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
