Gtr Parts, Sump, Fuel Pump, Intake/intercooler Piping, Complete Wiring Loom And Igniter, Afm's Etc Perth
doing a bit of a garage clean out. both stock and after markets parts for GTR's.
R33 GTR sump and front diff
Sump is off a 1995 R33 GTR. perfect condition, no damage. i wrecked the whole car about 6 months ago. is complete sump with front diff.
$300
NISMO Direct replacement fuel pump for R33 GTR
This is out of the gtr i wrecked, and was making 470 hpatws with this pump. comes complete with cradle aswell.
$180 ono
Complete R33 GTR wiring loom/harness including igniter pack
all plugs and loom are in good nick, and in complete working order. all plugs cables etc from pick included
$150
2x genuine factory JECS R34 GTR air flow meters
both in perfect working order, only taken off car due to upgrades.
$150 for the pair
GTR rb26 twin turbo intake pipe
as shown in pic, with clamps and emblem and joiner
$50
R33 and R34 OEM intercooler piping
have a 2x each piece of oem intercooler rubber piping, fits r33 and r34 gtrs. no cracks etc
$50 a piece
Skyline alternator
i had two alternators, one off a gtr, and one off a gtst, both where working in the cars. i sold one, but cant remember which one. this is the one i have left. please make sure its the one you need.
$50
Parts are all located in Perth. You can message on here or text/call me on if you are interested in any of the parts. some things negotiable. or if you buy more than 1 part etc.
cheers
  • 4 weeks later...
  • 3 weeks later...
 Share
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
    • Without better pictures, it won't be possible for anyone to work it out further than we have.   Start measuring, EVERYTHING. Thickness of flywheel, and all around it. You want to know is if everything parallel. If from the face of the pressure plate (that bolts to the flywheel) if it is parallel to the pressure plate face, then something is NOT parallel or equal elsewhere. Or you've bent the shit out of the fingers in the pressure plate.
