Hey guys done a fair bit of searching on this but have been unsuccessful...
R33 gtst series 2 rb25det
Splitfire packs
Apexi pod
Boost tee
FMIC
Stock turbo
Apexi power fc
So guys just had an apexi power fc installed on the 33 and the idle is rough when warm and cold, the cold start seems like it isn't even initiating on startup, when the clutch is in when coming to a full stop the revs drop dangerously low to about 400rpm and there's flat spots throughout the rev range oh and not to mention when I turned the air con off today on the way to work it stalled and then when I started the engine I had to keep the engine revs up or else the engine would shake and try and stall...
I'm not going to name the tuner as I wouldn't want to give them a bad name all I know is that they apparently didn't have the software on their laptops to suit the latest style of apexi units so instead they used the latest hand controller that came with the unit.
I'm sure a lot of the problems are tuning related and need to be fix via a tune but I would rather not pay to have something fixed because of poor tuning on their behalf.
Will a tuner fix their mistakes at their own costs or what? Because I'll be damned if I'm paying for them to fix it
Cheers
https://www.sau.com.au/forums/topic/436683-r33-tuning-issues/
Any good place will fix their caused issues. Provided they dont blame the car
They can't blame the car everything is running that smooth as anything prior to the ECU going in even had the car checked mechanically and it's running sound so the tuning is the culprit
Sounds like they suck. If they didn't have the correct software they shouldn't have done a half arse tune. I would doubt they would be able to fix it to an acceptable level anyway. like polishing a turd!
Edited by superben
Do you have an atmo BOV?
Those things dont sound to hard to fix, but with an atmo Bov, you may still get some stalling off throttle issues. Shouldnt stall when turning air con on or off. There are settings to prevent this.
Otherwise it might be a problem with your AAC/ICV. I think you can check something in SW/SENSOR CHECK on the power FC hand controller (if you have one)
Check the plugs, maybe adjust the base idle as well
Cheers for the input but it's the factory BOV to be honest I cannot stand the whoosh sound and would rather block it off....
I'm not going to mess with anything and will leave it down to the tuner to fix once they have done that I'll be off to see good old matty spry and get a real tune done
They gave you the car back running like that? Did they mention anything to you about the car running that way?
When i got my car worked on by my tuner, He got me to drive it and he sat in the passenger seat. Everything was fine and we were both happy.
They didn't test drive the vehicle on road but the car was running just fine before it was tuned
The only thing I noticed was the revs dropping very low when I came to a complete stop but it wasn't until the next day when the vehicle was cold that I noticed every little thing shaking and lumpy and hunting idle and then it got really bad one day and kept stalling
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
