Hey guys, just wondering whether it would be worth changing my stock intercooler for an R33 or 34 unit. Do they flow or cool any better? Would I be better off just saving for a front mount? (I know that would be heaps better, but I can't afford it for ages). Also do they bolt straight up? Any info or opinions would be appreciated. Thanks
https://www.sau.com.au/forums/topic/43670-r32-to-33-or-34-ic-upgrade/
i dont think there would be a significant difference between them, the 34 probably flows better. you can get trust cores for the stock sized one (triple core). best bet would be to source a r33 gtr intecooler (front mount) and use that. good for upto 300rwkw
should be able to get it for around $600 without piping
The R33 -> R34 GTT intercooler swap is an excellent cheap mod.
It bolts straight on and the volume increase is definately worth it. The best part though is the better airflow you get through the GTT core since the end tanks are larger and better designed.
The R33 intercooler seems awkward in comparison.
The 32's i/c pipes route differently to the 33/34's. On one side of the cooler (inlet i think) the pipe goes straight up into the engine bay. On the other side (outlet) the piping heads towards the front of the car on a 32... on a 33/34 it heads towards the back. You've just gotta get someone to re-locate the outlet pipe to the other side of the end tank. Dunno how much a pro would charge to do it, should be about $50 I reckon. Then you gotta mount it... I made my own but you can probly modify the stock ones. Lastly you'll need a 20cm or so length of intercooler hosing. to re-attach the modified outlet to the stock piping. Hope this helps
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
