Tell me more about these manualised autos
No electronic control required. You manually select each gear and enjoy the fact you don't need to push the clutch pedal and the best bit is you just keep grabbing gears in a skid
What shifters work? Do you need a new valvebody? What is exactly involved? How does the stall converter react to it? After a manualised auto you can use any stand alone? etc etc... Obviously i don't know anything about autos besides the fact that mine is in good nick. I'm guessing the cost is around the 1-2g mark?
Tried searching quite a lot and i couldn't find anything, and i don't want to waste MV's time by calling them.
A few posts up I have a photo of my b&m shifter under the factory covers. I suggest you give mv a call that way you get all your questions answered they are good guys to talk to
  • 4 weeks later...
Are these the options or tuning the auto skyline r33 :
Toshi's tune
Nistune..need more info about this
eManage blue/ultimate
Safc and sitc
Power Fc
Are these users able to retain the shift logic? Toshi is all out of auto ecu's and wont be importing anymore so I dont know if he is an option. He mentioned not being able to do over 200rwkw or so on the eManage.
Want to see in excess of 230rwkw (have usual mods - intake/exhaust , injectors , fuel pump - high flow turbo to 18psi , trans cooler , mv valve body upgrade)
What ecu can I use that will retain daily drivability but get me to 230rwkw?
Nistune, Nistune, Nistune, Nistune, Nistune, Nistune, Nistune with a side of Nistune.
Just Nistune.
Nistune is what you want.
Nistune is what everyone should want.
I also realised after I wrote Nistune a lot, that the person asking has a 33 Auto, to which I have NFI if Nistuning will work as they typically change the ECU to a Z32 or RB20 ECU to boot.
Unsure if that even applies to Autos, actually.
Oh i came here thinking that if i ask a question it would be automatically answered. Guess i came to the wrong neighbourhood.
Took me a while to get that. It was that good -_-
Edited by superben
Soo funny I forgot to laugh ;)
Stu cornall tuning services in qld is making them. Just sent him a msg on Facebook.
If he doesn't reply, does someone else want to call him? I've been watching him from afar and following him from work and home. I KNOW he has been ignoring me!
Edited by Stagea97
lol stalker much :)
Just Nistune.
FYI This is what the director of Nistune had to say after I emailed him regarding using nistune on an r33 automatic:
The only option I’ve found so far is to use the R32 ECU, TCU and an aftermarket VCT controller. This has been done by Steve at Advanced Jap Auto in Vic with indicated the setup works since the r33 TCU cannot be used with R32/Z32 ECUs
You would also need to upgrade the MAF to Z32 over 220rwkw
We cannot nistune the r33 ECU at this point. Another person is working on a solution but no news since Dec
If you wished to do this way then you need to source the R32 ecu and tcu plus Summit racing, buddy club etc RPM trigger switch for VCT and Nistune Type 2 board loaded with rb25 maps
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
