Hey guys just rebuilding my R34 after it had a crash and ive came across a bent part not sure whats its actually called looks like a track control link arm.
Was very difficult to put in, had to use a prybar to stretch it to line up to the bolt holes. Thats the drivers side the reason im not sure if its meant to bent like that is because it looks like a manufactured bend, normally when parts bend they flake paint or crease, this has none of that.
The passengers side is dead straight though
https://www.sau.com.au/forums/topic/436715-track-control-link-arm/
That bend doesn't look like it happened in a crash. By the same token, I've never seen a factory Nissan caster rod witha big curve in it like that.
Teh real question is, what is the length of that arm from front bolt centreline to the back bolt? If it's the same or very close to the length of the straight arm on the other side of the car, then it is a factory pre-bent arm to clear something or other on some car or other. If it is much shorter than the straight arm, then it has taken a big hit.
Either way, if the you have to pry it really hard to get it to fit up, then you are going to be pulling that wheel a looooong way forward in the wheel well, putting a lot of caster on that side, and a lot of strain into the upper and lower inner bushes on the suspension arms. Not good. Get it to a wheel alignment/chassis specialist (not a tyre shop!!!) and get it checked out. If there is residual lack-of-straightness in the front chassis then you will never get a good wheel alignment, tyre life or handling performance out of the car. Best to find out now I reckon. If you're in SA then I can recommend Stable Wheel Alignment in Pooraka. They are very good (they do this sort of work to get cars fixed up for crash repairers who cannot) although the main guy there is a pain in the arse to interact with sometimes (all the time!).
cheers
Nope - that's what the factory R34 caster/radius rod looks like on my GTT (bottom one):
My factory ones are bent similarly on both sides too (mirrored).
I have no idea why yours would be different on one side compared to the other?
Hmm thats weird... Mines only a GT but i doubt that would make the difference.
You shouldnt need to use a pry bar to get them in? Should they just line up to the bolt holes straight up?
You usually need to apply some force to fit them. I've never had to use a pry bar even when I've had my adjustables wound a bit shorter, but YMMV. As I said, get the car checked by a specialist if you're worried, especially given it's just back from the crashies.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
