Hi all,
I seem to be having some idle problems with my car, its a 1992 R32 GTR and I cant seem to find out what.
Basically any time im slowing down to a stop, the idle drops to around 600rpm, sounds like its about to die, all the electrics dim quickly, and then it slowly scavanges around to find the right idle (it normally idles at just under 1000rpm so when i slow down it does 600rpm -> 700rpm -> 600rpm -> 800rpm -> 700rpm -> 900rpm -> 800rpm -> 1000rpm). It also occasionally stalls if it cant pull the idle back up.
This only started happening after I didnt drive the car for 3 days straight (it usually gets started every second day at least).
The car has a power fc, and in the sensor checks it reports one of the 02 sensors as being 0.02v (dead) but it has always been like this, and nothing has changed in the period of time before it was running fine, and after it started playing up.
Any ideas/feedback would be appreciated.
https://www.sau.com.au/forums/topic/43673-bnr32-idle-problems/
It can be an atmo BOV as unwritten law said. My car has idle problems but i know its normal because it is heavily modified. Sometimes the car is already at idle and then the RPM just goes up and down up and down, and the internal lights dim. Hate when it does that but every mechanic ive seen, they say it it becasue of the Modifications. I know this might sound stupid, but try to reset your computer.
Well the car has had atmo bov's (blitz supersonic dd's) since I bought it, and it used to run fine without a problem... just in that weekend something seems to have changed, and its never run properly on decelleration since...
Nik
Sounds to me like a vacuum leak - I have the same thing on my NA d/driver. (it has vac leaks, but I don't like working on it!!)
Check all of the emission lines (one might be cracked, or could have been knocked off). If that doesn't locate anything I'll think about it some more and tell you my ideas on Satuday : )
Cheers
Dan
(BTW - no car should 'hunt' at low idle, if a car is very worked it will be lumpy, but not hunt - I grew up with angry V8's
Yeah it runs fine accelerating and top end (it feels a bit choked top end but im putting that down to my exhaust which is being replaced saturday) just as DAN00H said, hunts for idle when i come to a stop. Vacuum according to the AVC-R seems to be ok, and it doesnt jump around alot when off throttle of stopped, but I will check all vacuum lines etc this weekend.
what i've found from experience is several factors:
atmo bov failing - it might have been alright before, but as it gets older, it may be leaking
weak fuel pump and almost empty tank - just before my fuel pump died, it seemed to have trouble sucking enough fuel when the tank is empty (very little downpressure)
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
