hey guys
i am contemplating whether i should get rid of the skyline and upgrade to a nissan murano as the family is growing.. so i just want to try and see how much interest and how much i can get for it. im hoping of getting around the $13.5K. so give me a offer.
i thought i'd post it up here first so all the V-series enthusiast can have a chance before i advertise to general public on carsales.
the car has been a wonder to drive. it has always made me smile when i put my foot down. and smooth when needed for just normal daily driving. the car has always been well kept, washed every 2nd week, well looked after and always serviced on time. and for the guys that are always negative about the cvt, dont worry its has been serviced 10000KM ago. it drives perfectly silky smooth!
those who have seen the car will vouch for me.
here's the details
Make: NIssan
Model: Skyline V35 350GT-8
Year: 2003
Transmission: CVT 8-Speed
Color: Midnight Blue
Rego: Just under 5 months
KM:just below 150000
here's the list of goodies.
engine
-custom exhaust system with VIP styled exhaust tips
-blox intake manifold spacer
-dynamics throttle body spacer
-pop charger with z-tube
brakes/supsension/wheeks
-tein coilovers (driving master spec - to get the VIP ride height and have the comfort available still)
-project mu disc rotors (front and rear)
-qfm brake pads (front and rear)
-genuine sparco 18x8.5 18x9.5
-super pro front lca bush
exterior
-nismo lip kit
-wald bootlid ducktail
-series 2 front bar
-series 2 boot lid
-series 2 outter tail lights
-10000K hid globes
-yellow jdm foglight/hi beam globes
-led number plate light
-led park lights
interior
-diy aux cable
-reverse camera integrated into factory screen
-translated factory screen
-tv tuner
-led cabin lights all around
-led front door courtesy lights
i may have left a few things out. but all in all the car drives well and is perfect. the only blemishes are a few little dings here and there from the age of the car. other than that it would be one of the best v35 sedans around.
pics will be up later.
PM if u have offers or enquiries.
cheers
jo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
