Actually, I'm speaking with a company in USA.. they produce 220amps ( https://www.dcpowerinc.com/high-output-alternators.html?make=Nissan&model=Quest) I sent them an email and they are currenctly beta-testing one for a RB in a 240sx.
Should be available this winter once they done with testing and said I will be the first one to order one :P
600+ KWs,fuel systems alone takes 32amps,ive already blown 2 secondhand alternators and the brand new one im using is getting very hot!As im an electrician i understand all your electricals should be at least 150% overkill for reliability.Checked out the RH9 mentioned above,sounds the goods,but $1000 once you ship from UK,found a website in Japan that can get one to me for $610,this will be my christmas present.Thanks for the help guys
What are you running to warrant 150 amp?
add fuel pump and audio amp and your in for at least 150.. so if you want a bit of space in case of.. then you need a 180 amp.. Actually I calculated I needed about 200amps. I bet my ignition and throlle will feel snappier once I install the new alt.
:thumbsup:
If you want Nissan OE the go seems to be later Maximas with all the elec options . I know we got Hitachi 110 a alternators here but the belt tensioner mount is in a different position on the I think front casing . I have a 110a one here gutted for when I get around to needing an alternator , for me 110a replacing 80 should be fine .
I never got around to researching Mitsubishi alternators to see if there's anything better than 80 for an RB25 that's direct fit .
Something to remember with high output alternators is that the rotor is usually considerably heavier so revolving inertia to have to accelerate and decelerate . Note the pulleys get wider for contact area so they don't slip . Also some big late alternators have some wacky decoupling guts type pulleys I think so the alt can run faster than its pulley sort of like the free wheel on a pushbike . Probably makes life easier for the belts and off throttle engine transients .
A .
either RH9 hyper alternator 130 amp or Advance Black Alternator 130 amp both about same price
you can get for under $600 from www.rhdjapan.com cheaper when they run weekend specials
difference between both is just Cosmetic first is Blue & Silver ( blue pulley )
& the second Red & Black ( red Pulley )
got my RH9 within 6 days from them to Country Victoria.
The ones to research are late luxo barges that had a filming studios worth of electronic poser crap . These often have high output alternators to run all this crap at virtually idle for traffic driving .
Unfortunately we didn't get the real Nissan lux sedan , Infinity , like they do in the states . We got fobbed off with the Maxima FWD POS though the real one is available here now .
Also worth researching late four tonne drives because these are often rolling lounge rooms with all the crap as well .
A .
I had a bit more of a sniff into Mitsubishi brand alternators since some Skylines have them and it looks like its easier to have a win with them than later Hitachis - exc maybe late Maxima 110a ones .
So far the highest output one I've found is off a Mitsy 4B11 and it's 12v 130a . Search for 130a Mitsubishi alternator because I can't post the link .
Also things like RX7 Ser 6 7 8 and Pajeros have Mitsy alternators in the 90-110a range .
Be good it their guts went into Skyline Mitsy casings , cheers A .
Edited by discopotato03
Can an alternator rewinder/repairer bump up the output of a standard alternator?
Obviously they'd need to change regulator as well but wondering do they add extra windings or something to bump them up?
Yes they can,but only old school auto electricians can do it,and can be quite pricey.Thats what we did years ago,remember turning a 25amp one up to 45amp for a torana,that was hi tech in the day.Much easier now just to buy one.
I fitted one from a 2010 turbo diesel patrol I think...not sure exactly what year it was, but it didn't have the vacuum pump attached to it. I believe it was rated at 130amps also.. Was about $500 brand new from Nissan spare parts. It was not a direct bolt up though, I did have to machine up a linkage so it could still adjust belt tension. Bolted to the block the same but the lug to pick up the slotted adjuster bracket was in a different spot, hence the linkage.
I found another possible in Nissan Muranos , I think they have a Hitachi 110a alternator 2003-2010 and a 130a from 2011 to 2013 ?
BTW can an auto sparky tell me if you have to wire up the 3rd and 4th pins used on later alternators ? I think the engines computer must have some control over charging loads possibly for emissions BS reasons .
A .
hi Brandon - I had the RH9 Alternator installed on my R32 GTR just prior to Christmas.
It was direct bolt on.
However, they did put a new inline fuse in mine. Will find out the ampage and reason in the next day or so.
Cool. Please do. By the way, do you know if the alternator comes with voltage regulator or are they external? I'm wondering if that might be faulty. Any case, I've placed an order for the RH9 alternator, hopefully its all good.
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
