I got lucky today and found a 125a alternator that looks like a Hitachi and a noticeably wider in the outer metal section between the ally casings . I found it by mistake in a wrecker 92 Maxima with an early VG30 in it . Usually the 110a ones turn up on 97 98 A32 Maximas with VQ30s in them .
The mounting ears are the same with the front tensioner one on centre so to speak . RB alternators being on the drivers side have the top ear slightly towards the engine so need to mod the top bracket to suit the Maxima alts . Maxima VQs don't tension the drive belt by moving the alternatorand and depending on the year and VG/VQ engine can be above or below the AC compressor . I scored a slotted tensioner bracket from an early bottom mount car and another from some top mount Nissan , transverse KA I think . I also got the threaded adjuster block and bolts off some Nissan that tensions by hinging the alternator RB style .
These later alternators have a different connection to the early large spade type . I only have one good plug and I'll have to see what my car has standard .
$45 for a second hand 125a alt sounds good to me , cheers A .
Edited by discopotato03
Yeah I have a string of alternators off various Jap things now starting with an LR165 off a Vortex and the Z32 LR180 that replaced it .
I scored a genuine Hitachi LR1110 (110a) which had been freshened up for the R33 , then stumbled on the 125a one which I pretty sure is a rebuilt Hitachi LR11125 in Maxima casings .
You see the odd copy of Hitachi alts and you can tell by there being no Hitachi stickers and the plating on the nuts and bolts is silver not that gold appearance .
Anyway we split the cases off the 125 and washed it all up yesterday arvo . All looks pretty good though the back bearing is a bit tired .
I honestly think 110a is plenty to have in a car that has 80 standard particularly a 90s Skyline without all the luxo elec pork .
One of my failings is I can't resist rare upspec bits particularly when the bite is virtually trivial .
Must stop collect alternators , cheers A .
Yeah well it works out to around $155 cleaned tested and with new NTC (OE) bearings if the reg rectifier and brushes are good . That's with the help of a mate and the workshop with $50 their way because I don't use people .
The RH9 one has the better front case tensioner mount position but even having to make or mod the bracket it's heaps cheaper and any Maximer alt with the right pulley and socket goes bolt plug . $155 vs 6-900 , the plain lookin one wins .
I'm reluctant to think there is anything special in the RH9 one and if there is it could be higher speed bearings - and lairy paint .
Of course a bright blue pully and stator is worth at least a second in the quarter ... 100% !
A .
  • 5 weeks later...
Any one heard that the I30 160amp are straight bolt-on affair ? a chap in UK said it was straight bolt on on his r32.
I'm trying to buy one from mechman or DC power in the state.. but none are willing to take a R32 case and rebuilt it or make a custom one.. obviously they must think the market is not there and they wont sell enough for them to make it worth it.
  • 2 months later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
