yeah, first thing I did. at idle its lost 0.75V from about a year ago, and battery is in good shape.
yeah that sounds like it's on it's way out
Mine was loosing voltage at idle after a bit of driving now she's at 13.5
Good to hear ants.. I still haven't installed mine but I'm guessing there will be a massive improvement due to the old alternator being 10amps lower then stock.. That and I was running 3 fuel pumps
its an easy job imo.
It makes a difference alright and better spark too
I had this problem too. Ruining three 044, ac, stereo, amp, spitfires, HKS twin power, ect.
Had an auto elec modified it, windings, rectifier i think . Can't remember of the top of my head the amp it was changed to but was a lot above the standard r32 gtr.
Had on problems since was only around $200 and that was fitted.
If your in Brisbane it was, service really good they dropped me off and picked me up too, but I'm local:
AC-DC Auto Electrics
4 Bonemill Rd.
Runcorn QLD 4113
I'm not associated with them in anyway just great guys, hard to find in the auto industry up here
Edited by Xing Yi
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
