hi guys
just looking for some info on single and twin plate to suit s2 rb25det neo manual stagea
I have heard r33 gtr clutches fit
also r34 gtt
can you verify this ???????
pretty much which product codes will fit
also I have around 450hp at all four
which clutch would suit this eg orc 559 , nismo copper,nismo gmax, os giken
at the moment I am running 409d orc but will not last long
say budget of no more then $2,000
so all in all looking on info of what will fit and whats everyones opinions of a great clutch for the horsepower is
as I am doing a lot of track days ,hill climbs and abit of strip work
cheers
A single will do it fine mine holds fine with 340+kw, 6 puck extreme clutch, nice hard launches, what mods have you got done to the neo for your power figs
mods;
cometic head gasket
garret gt35
1000cc inj with billet rail
low mount steam pipe manifold
s/s dump and exhaust
tomei pon cams and gears
port and polished head
plazamamann cooler
niztune ecu
arp studs blah blah blah
running e85
just waiting to finish my forged 30 bottom end
as above I do a lot of track days and hill climbs ... street drivability isn't so much of a prob
What's the turbo come on like with the gt35 on a neo? Nearly went that way but stayed with a 3076 .63 hits like a shotgun when it Comes on and still makes 200kw by 4000 e85 as well only running 17psi ATM chuck up some dyno sheets if ya got some would be keen to have a look, what suspension mods and brakes ya running
Cheers jase
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
