Sklyine S2 Rb25Det Engine Problem
Ben r33 s2
 Share
Hey guys, need some help! went for a cruise up to the river and when i hit speed of 100 and over i noticed the engine started to back of a bit and i had to put my thought down on the pedal to keep it at the speed. something seem to be giving the engine a hard time. after driving it for 70k or so it went away. And was fine half way back on the trip home but then the problem started again. Don"t know a great deal about cars. thinking it could be a fuel pump issue other wise not sure wondering if anyone else has had this problem?
As mentioned above there is a whole lot of things that could have the symptoms your car is showing mate. Personally I would start with a quick service and see how it goes. Change the oil, oil filter and spark plugs. Give the afm a bit of a clean out and see how that goes. Could be a simple as that or much more needs to be investigated.
Goodluck and hope its not too much of a headache in getting this issue resolved.
haha same sigh i had just few days ago and shaun at bootsworx fixed for me....first thing you can do take your AFM off clean it properly and then you have to cut open AFM and resolder all the joints in side.
Thats what shaun did for me and car touchwood fine since...
 Share
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
