Hey guys, need some help! went for a cruise up to the river and when i hit speed of 100 and over i noticed the engine started to back of a bit and i had to put my thought down on the pedal to keep it at the speed. something seem to be giving the engine a hard time. after driving it for 70k or so it went away. And was fine half way back on the trip home but then the problem started again. Don"t know a great deal about cars. thinking it could be a fuel pump issue other wise not sure wondering if anyone else has had this problem?
https://www.sau.com.au/forums/topic/436784-sklyine-s2-rb25det-engine-problem/
As mentioned above there is a whole lot of things that could have the symptoms your car is showing mate. Personally I would start with a quick service and see how it goes. Change the oil, oil filter and spark plugs. Give the afm a bit of a clean out and see how that goes. Could be a simple as that or much more needs to be investigated.
Goodluck and hope its not too much of a headache in getting this issue resolved.
haha same sigh i had just few days ago and shaun at bootsworx fixed for me....first thing you can do take your AFM off clean it properly and then you have to cut open AFM and resolder all the joints in side.
Thats what shaun did for me and car touchwood fine since...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
