For Sale:
R32 GTR rolling shell 1992 model in Black, non vspec
-Complied, registrable straight chassis with excellent paint on shell
-Previously registered in QLD
-Will come rolling with standard suspension in the front and lowered king springs in the back, on space savers.
-Zero drive line, however rear subframe is there to keep rolling with hubs, no diff/shafts. Front hubs and arms there, no front brakes, rear brakes are there with handbrake still in place.
- No panels/lights left on car
- All glass and regs are there
-Engine bay has everything removed except rack and cross member
-Inside is completely empty except handbrake, pedals, steering column, rear seat belts and vehicle loom
-Fuel tank and fuel flap all still in vehicle
-Attessa all wheel drive pump, lines and reservoir all still there
-Is as is in pictures, except today the engine bay was painted gloss black, gearbox & the last few panels have been removed and had space savers fitted.
-Will suit perfectly for a track car, project restoration, or donor car it your own R32 GTR shell is damaged
-Has all chassis plates and compliance plates also
Is ready to be picked up, rolling on space savers with handbrake operational
$1800
Located Gold Coast
0414596256
https://www.sau.com.au/forums/topic/436786-r32-gtr-rolling-shell-complied/
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
