For Sale:
R32 GTR rolling shell 1992 model in Black, non vspec
-Complied, registrable straight chassis with excellent paint on shell
-Previously registered in QLD
-Will come rolling with standard suspension in the front and lowered king springs in the back, on space savers.
-Zero drive line, however rear subframe is there to keep rolling with hubs, no diff/shafts. Front hubs and arms there, no front brakes, rear brakes are there with handbrake still in place.
- No panels/lights left on car
- All glass and regs are there
-Engine bay has everything removed except rack and cross member
-Inside is completely empty except handbrake, pedals, steering column, rear seat belts and vehicle loom
-Fuel tank and fuel flap all still in vehicle
-Attessa all wheel drive pump, lines and reservoir all still there
-Is as is in pictures, except today the engine bay was painted gloss black, gearbox & the last few panels have been removed and had space savers fitted.
-Will suit perfectly for a track car, project restoration, or donor car it your own R32 GTR shell is damaged
-Has all chassis plates and compliance plates also
Is ready to be picked up, rolling on space savers with handbrake operational
$1800
Located Gold Coast
0414596256
https://www.sau.com.au/forums/topic/436786-r32-gtr-rolling-shell-complied/
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
