Hi all. I bought the car back in September. Had all the maintenance done that it required etc etc. Part of the work done included new belts as they hadnt ever been done. Yesterday two out of three belts came off. I checked the belts, they all have the same markings on them, so either they were all replaced or none of them were. My receipts states that they were.
Extent of damage thus far is not known apart from what I can see.
Belt for the alternator is gone
Belt for the thermo fan is also gone
When the belt for the fan came off, the fan came loose, sheared off from everything. In doing so it has sliced at least one radiator hose and taken out the radiator completely.
The last belt is still on. To the best of my knowledge this all took place in my driveway when moving the car. So damage may be minimal? I have no idea.
Given that I have an invoice to the tune of $1500 that included new belts, they should last a lot longer than six or seven thousand km's. So who is at fault here? Belts are supposed to be good for around the 100k mark, maybe a tad less depending on car and application.
There is a fair chunk of work here and I genuinely dont see how any of this up and coming repair bill is mine in any way shape or form. If this were your problem, how would you go about it? Obviously i have to contact my mechanic and tell him whats happened at some point and see how they feel about it.
What are your thoughts? What would you do?
In the first instance contact the shop that did the work as soon as possible.
Could be tricky as they may be closed for Christmas.
Do they belong to a trade association to which you can complain if necessary?
Make some enquiries about the relevant consumer protection laws so you can quote them if necessary.
In this country the last resort would be the small claims court/ disputes tribunal
But try the direct approach first and be calm and polite but insistent!
Damage is likely to be limited to what you have observed unless the cambelt has also gone - which is unlikely.
This exact thing happened to the 25G. The fan/waterpump belt was overtightened. The water pump shaft sheared. The fan had a whirling orgasm under the bonnet.
New radiator, new (VL) water pump, new belts.
Call the shop first thing for sure. The belt could have been over tightened putting big pressure on water pump and if the fan bolts were left loose then it would do 2 hat you are saying for sure. They are at fault
Hey all. Thanks for the responses. As you can see I am no mechanic and have only mentioned what I can see. So, from what I have described, no internal damage to the engine then?
Yep, wrong time of year. I will give them a call tomorrow and see what happens.
No internal damage, so don't stress.
Let us know how you go!
Belts only cost about $30 - if there is no other damage I wouldn't bother arguing with them - if your located in western Sydney I'd be more than happy to refit them for free for ya...
Problem is these dodgy mechanics always find a reason to not be liable for their f**k ups!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
