Hi all. I bought the car back in September. Had all the maintenance done that it required etc etc. Part of the work done included new belts as they hadnt ever been done. Yesterday two out of three belts came off. I checked the belts, they all have the same markings on them, so either they were all replaced or none of them were. My receipts states that they were.
Extent of damage thus far is not known apart from what I can see.
Belt for the alternator is gone
Belt for the thermo fan is also gone
When the belt for the fan came off, the fan came loose, sheared off from everything. In doing so it has sliced at least one radiator hose and taken out the radiator completely.
The last belt is still on. To the best of my knowledge this all took place in my driveway when moving the car. So damage may be minimal? I have no idea.
Given that I have an invoice to the tune of $1500 that included new belts, they should last a lot longer than six or seven thousand km's. So who is at fault here? Belts are supposed to be good for around the 100k mark, maybe a tad less depending on car and application.
There is a fair chunk of work here and I genuinely dont see how any of this up and coming repair bill is mine in any way shape or form. If this were your problem, how would you go about it? Obviously i have to contact my mechanic and tell him whats happened at some point and see how they feel about it.
What are your thoughts? What would you do?
In the first instance contact the shop that did the work as soon as possible.
Could be tricky as they may be closed for Christmas.
Do they belong to a trade association to which you can complain if necessary?
Make some enquiries about the relevant consumer protection laws so you can quote them if necessary.
In this country the last resort would be the small claims court/ disputes tribunal
But try the direct approach first and be calm and polite but insistent!
Damage is likely to be limited to what you have observed unless the cambelt has also gone - which is unlikely.
This exact thing happened to the 25G. The fan/waterpump belt was overtightened. The water pump shaft sheared. The fan had a whirling orgasm under the bonnet.
New radiator, new (VL) water pump, new belts.
Call the shop first thing for sure. The belt could have been over tightened putting big pressure on water pump and if the fan bolts were left loose then it would do 2 hat you are saying for sure. They are at fault
Hey all. Thanks for the responses. As you can see I am no mechanic and have only mentioned what I can see. So, from what I have described, no internal damage to the engine then?
Yep, wrong time of year. I will give them a call tomorrow and see what happens.
No internal damage, so don't stress.
Let us know how you go!
Belts only cost about $30 - if there is no other damage I wouldn't bother arguing with them - if your located in western Sydney I'd be more than happy to refit them for free for ya...
Problem is these dodgy mechanics always find a reason to not be liable for their f**k ups!
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
