Hi SAU
I've had a recent issue with my R32 GT-R in regards to the vehicle not starting.
The situation is that I parked the car in the shed and threw a cover over it. Upon returning two days later to take the car out for a drive, it simply wouldn't start.
The starter motor does turn over, the fuel pump primes when the key is rotated to the ignition barrel and there are no fault codes being identified by the ECU. It just won't turn over and start. I have dropped the fuel, threw the battery on a trickle charge and tried a few days later but to no avail.
Any insightful information to direct me to the cause of the problem would be much appreciated.
https://www.sau.com.au/forums/topic/436817-r32-gt-r-not-starting/
I'd try another battery. Trickle charging a faulty battery is a waste of time.
+1 and batteries can do funny thnings when old or dying, could be enough charge to crank but not enough for fueling and/or ignitionn etc..
Check you earth lead, make sure its grounded properly to the engine/chassis..
I once spent a week chasing what i thought was a dead starter, it turned out being that i needed to remove the ground leads everywhere and sand all the points.
Boy did i feel like a useless carnt after working that one out.....
I've tried 3 batteries, all to the same result. Although, the newest one did sound like it was the closest.
PaulosECR33; It doesn't try to fire at all, starter motor just keeps turning over to nothing.
I'm going to change the plugs and fuel filter at some point and have another crack.
I'll also have a look at the earth leads and make sure they're all in order.
Will report back with any new developments but don't hesitate to keep bouncing ideas off me.
Take off the cas and turn it by hand with ignition on. should be able to hear the injectors firing, and pull a coilpack off abd check for spark at the same time . They should give you more info as to what the prob us.
it is worth trying this old chestnut right now because it can be the issue (I know from experience - today!)
Ignitor - swap with a friend who has one. 5 minutes will rule it in or out :thumbsup: and is the easiest thing to do
need a 4mm allen key and 5 minutes
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
