I was told the vl (rb30) water pump fits the rb25's, but i was just wondering if anyone knew if they fit the rb20det as well??
Also, can anyone give me a quick run down on removal and install of a water pump.
This is how i see it,
*use white out to mark where cas sits on timing cover as i don't have a timing gun
*remove cas
*remove timing cover
*mark appropriate spots with white out so timing belt goes straight back in original position
*remove water pump after draining coolant system
*clean around the area with a rag etc and apply gasket with some gasket goo (any suggestions? )
*install new water pump
*put timing belt back on inline with white marks
*put all covers back on
Any suggestions/tips etc would be great.
cheers
Jayson
https://www.sau.com.au/forums/topic/43687-water-pump-queries/
I reworded my search and got a few more results. So far i have removed mostly everything except for the harmonic balancer. I've cracked the centre nut but now need a harmonic puller to remove it. I paid $74.50 for a rb30 water pump (Protech) and had some gasket goo around so all up it should hopefully only cost me $74.50.
Joel the rb30 water pump seems identical to me. The only difference being that the top 10mm bolt hole is not slotted like the nissan one.
Cheers
Jayson
There is a "powermax" one for like $80 from some parts places I've noticed (supercheap, etc).. Fit sheet says RB26DETT, RB25DET, RB30E, and RB25DE so if you ask me that sounds universal :P
They missed RB20DE and RB20DET and RB30ET. :slap:
So it is confirmed the rb20det motor will use an aussie delivered r31 skyline rb30 water pump....
Yes, definitely, absolutely, not a problem, all RB water pumps are interchangeable, go for it, let 'er rip, whack it on, bolts straight up etc etc.
You need to be aware that while they fit, there are slight differences in performance.
The RB20DE pump flows slightly less water at all RPM's (smallest engine, needs less cooling).
The RB26DETT pump flows slightly less water at high rpm (stops cavitation). :)
The RB26DETT N1 pump actually flows less than the standard pump for sustained high rpm use (racing). :idea:
The RB30E and RB30ET pumps are not designed for sustained high rpm (over 7,000 rpm), they are SOHC remember.
The RB20DET and RB25DET pumps are pretty similar in flow, but the impellers look different. :confused:
I think the RB25DE pump is prety much the same as the RB20DE pump but I haven't had them side by side to compare.
Hope that helps
So what would be the right choice of water pump for a lower rpm 800hp Rb30/26
Standard RB26DETT would be my choice. There is one on my RB31DET, so I guess you could say I have put my money (or faith) where my mouth is. :)
  • 3 months later...
sorry for digin the thread up again but im in the process of upgrading my water pump and have a few questions.
i wanted to upgrade to the N1 but syd kid says there is less flow than standard so does that mean for daily use and the occasional track/drift days its not worth it?
does the stock RB26dett water pump flow better than the stock RB25det??
anyone??
Maybe I am the only one who has compared them, but the spec sheet confirms it. The N1 water pump is specifically designed for continuous high rpm use, so it doesn't cavitate. This means it pumps less water around at lower rpm. So if you use your RB26 a lot (only) on the track, an N1 water pump is maybe worthwhile. But driving around the street it will be a handicap, maybe on hot days with the aircon on, in traffic. The RB30 pump is much better for this as it was designed for lower (average) rpm.
That's all for me :birdie:
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
