Hi guys,
When I bought my R34 all the vac hoses were muddled and I'm in need of some help as I cannot find the information anywhere else.
Firstly, is it completely ok for the charcoal cannister to be removed from a r34? As it has the Solenoid Valve which controls the purge. Do I just block everything off except for the fuel tank breather?
I am currently using a manual boost controller and the OEM solenoid is disconnected. Is it perfectly ok to connect it to this nipple on the hot side of the intercooler piping straight to the wastegate actuator?
Where does the nipple on the BOV recirculation pipe need to be connected to? This is the nipple just before the BOV line goes back into the intake.
It can just be seen here where the vac line connects (on the left)
Cheers
Edited by owen1r
https://www.sau.com.au/forums/topic/436894-r34-gt-t-vacuum-lines/
Wastegate line should be fed from as close to the turbo outlet as possible to the actuator. I think the vac line you have pictured (coming from the intake tube to the turbo) is for the stock boost solenoid and was blocked off on mine
The BOV needs a feed from the intake manifold because you need the vacumm under closed throttle to help lift the BOV off its seat
Thanks, I've now blocked off the recirc pipe and the pipe going to the canister control solenoid.
Only confused about the lines running out of the canister, there are two and both go to hard lines. They then split and run down each side of the vehicle, i've traced the passenger side one back to the fuel tank but I can't find where the one of the drivers side goes.
Why not leave the hoses/charcoal cannister connected? There is no power gain to be had by removing them and if the car is registeted for the road the cops can give you a defect notice
Yeah as above.
Just trying to remember what lines go were. I had mine hooked up wrong for ages and it wasnt letting the fuel tank breathe real well.
I think one line goes to the tank (sounds like that one is connected), 1 goes to the throttle body vac port (cooler side of TB), one goes to the intake manifold, and I think one is just a vent near the wheel arch? Not sure about the 4th line
I might order some hoses to replace the split ones but for now wanted to eliminate that as a possible cause for a missfire issue I have.
I've tried -
Spark plugs .8mm
Fuel filter
Boost leaks
Reverted boost back to stock.
O2 sensor
Ordered split fires, any other ideas? Missfire is mostly below 4k rpm.
Cheers
Missfire can mostly be noticed below 4k rpm.
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
