Harness Bar...?
Adz2332
 Share
Hey all,
Lots of people have different opionions re harness bars.
Im looking at running one in the r33 gtst (pic below of style)
What are peoples takes on these?
Also with that type of bar is harness mounting to the rear seat belt mounts? and the lap part to the normal front seat belt holes?
what is the better option 4 or 6 point harness? I wont be running hans...
And also the middle clip seems to differ alot. whats the easiest to use? pics?
Thanks
if you hop in the back and swing on it, you can move it about 2 inches up or down
once the harness is tight it doesnt move as its tentioned up
if it did move it would only tighten the harnes on your chest ( unlike the one in your pick above which is in compression and if something got loose your head smashes the steering wheel... ;) but r31 owners dont think of these things)
That looks pretty good.
It might just be the angle, but it seems like the harness might be resting on the back of the seat though
I recently went through the process of sourcing and reinstalling all the standard rear trim inc parcel shelf and seats. May touch it but it'll be very close and the rear back part has a bit of extra foam on it that sticks out to hide gap between the parcel shelf. Shouldn't be an issue.
Might call them up and ask them how much for the bar. Looks to be very easy to install.
  • 5 months later...
  • 1 month later...
Did u end up getting a price on that harness bar as it totally looks the goods to me!
I looked into harness bars about 9 months ago and ended up getting a half cage with harness bar. I found that a good harness bar was going to be $600-700, and a half cams approved cage with paperwork was a bit over $900 from Fabraications.
For the extra couple of hundred I also have roll over protection and a stiffer chassis. All my squeaks and rattles have gone. It feels like a brand new car!
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
