What's up guys !
Can someone plz plz give me a hand with this hey,
this is serious driving me insane !! :cheers:
Couple of month ago I bought a 1992 Sliver GTR R32 from
Melbourne for a good price, I only paid $28,000 for it , after the
car passed the inspection from Melbourne, I paid $1,450 to
get it over in Brisbane, then another $900 to register it..
And a couple of weeks ago white smoke starts to come out
form the exhaust, well... I didn't really give a thing in the start,
but it keep on happaning so I took it to the work shop.
I thought it's probably my turbo is getting old,
time to chuck a new one on it.
Unfortunally the mechanic walks out and told me the turbo is
quite fine, so there could be a problem with the engine. so then
we did a Engine Comperssure test, the first 3 cylinders was all good,
but drop the compressure on the last 3 cylinders ...OMG @#$%@& :):);)
and the gearbox oil is leaking .... and all this problems..
This is been bothering me to the max , I have already spend over 30k on the car,
and it just ........
And i thought it passed the inspection in Melbourne, ..
and the guy I bought the car from,
his phone is switched off...@#$@%%
next time I better not buy a car without seeing it hey ..
So.. PLZ.. somebody give me some ideas
where should I go to do a Engine Rebuilt,
I live in Brissy , and also where should I buy clutches,
cos the clutch on the car is gettign sliper and sliper.. @#@$% :D
=Skylineinsane=
https://www.sau.com.au/forums/topic/43693-92-gtr-r32-engine-blowing-up-help/
Your story with the pre-purchase inspections sounds just like mine.
They didn't check anything and when i actually bought the car it came with a few costly and unexpected problems...Something which i hadn't budgeted for :(
You have my sympathy.
You do get what you pay for with GTR's, but Marty @ John White Racing Engine does a nice job.
I'd be getting a 2nd opinion though.. white smoke? Oil or steam? Under load or cruise? Hot or cold? What are the compression figures?
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
