A few random parts sitting around, all located on the central coast, or once I return to work in the new year I can possibly deliver/meet in hornsby area. Id like to avoid postage just due to time constraints, small items I could be be open to postage never hurts to ask....
open to offers but most things are pretty cheap already, I can only say no, feel free to ask questions.
r33 gtst turbo with blown front bearing. $30
also comes with both std manifold and turbo heat shields with brackets
has a r34 elbow that I had leftover
solid factory oil/water lines $30
have a few different banjo bolts and stuff I can throw in if they help you out
complete set of std 33 series 2 injectors, replaced with larger at 90,000Ks
$50
SR20 sandwich plate, 2 x sensor holes $50
r33 series 2
drivers door trim few small marks on the material section but otherwise schmick $20
rear seat side trims, schmick both for $20
std silver wing mirrors removed to fit aftermarket ones, both completely schmick $30
also have brake and clutch pedal rubbers removed to fit vspec pedal set, $free
Original r33 series 2 lip $30
has damage as per pics, I replaced mine with a new aftermarket one. original std silver
post-26316-0-92143900-1388459118_thumb.jpgpost-26316-0-27303900-1388459129_thumb.jpgpost-26316-0-74233200-1388459138_thumb.jpg
Std series 2 fuel pump $30
replaced with larger bosch, about 90,000Ks on it
Hicas unit series 2, removed for lock bar $10
I think this is a q45 throttle body with tps $30
Std rubber brake lines replaced with braided lines $30
a couple of braided lines leftover from other stuff Ive bought over the years, app & brakequip brands $30
Origin under lip canards, never used or fitted one still in bubble wrap how it arrived from japan.
$100
