For sale: 1995 Holden Statesman, VS Series 1, 5ltr V8, auto
Price and price conditions: $3000 obo
Contact Details: 0419 780 483
Condition:
Mechanicals: excellent
Cosmetics: poor condition paint
  • Rebuilt transmission, very tight
  • Big transmission cooler
  • Hayman Reese Heavy Duty Tow Bar
  • Near new Monroe GT Gas Shocks
  • New strut top bushes
  • New caster rod bushes
  • New Slotted rotors with hi-temp racespec pads up front to cope with towing
  • Near new rotors/pads in rear
  • Lowered very slightly
  • Catback exhaust
  • VT SS wheels with good tread on tyres
  • just had radiator flushed and new coolant
  • new rocker cover gaskets
  • 270,000kms approx (cluster had an issue a year ago, so replaced it with another dash, so kms are not accurate)
Car was driven by a VR/VS statesman specialist the other month when it was serviced and he commented on how he hasnt driven one in such good condition for years. The car drives very straight, never skips a beat, just looks poorly because of the paint.
Aircon is gassed but has some issues, haven't had quoted to fix.
$3k may seem a bit steep considering the paint, but this car is perfect for towing, HD shocks, HD towbar, rebuilt trans with cooler. Won't need to do anything to it, completely ready to tow.
Only selling as I'm going back to 1 car setup. Funnily enough I have never towed with this as my track car is still on jacks. Only used car as a backup daily when my r32 skyline daily broke down
Pictures:
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
