As the title suggests, after destroying 2 cylinders and the deck in an n1 block, I'm looking at a sleeve and grout job on the next engine. I'm chasing REAL WORLD FACTS about the pros and cons. I've searched the subject and it's very inconclusive. I don't need to hear about joe blow making 1000 on a stock block because I don't give a frack, I'm looking for torque and peak torque and lots of timing mean biiiig cylinder pressures.
Thanks in advance, and happy new year
https://www.sau.com.au/forums/topic/436965-ductile-sleeving-rb-engine-blocks/
Actually if you Google there is a lot of reading on sleeving RBs with generic sleeves or OS Giken or Apexi . Grout filling of RB30s in is common and there are a coupe of threads on doing it in RB26s as well so I guess you just need to price some sleeves, the machining and decide whether its a better road than a new N1 block. There is a variety of cylinder wall coatings you can do as well so there is plenty of choice. If you want real world experience check out Rips big power engines. I don't think he's into sleeving but he certainly uses grout.
But as above if you are destroying engines I would think assembly and tuning play a bigger part. At what KW and revs are your engines breaking?
Central qld. People have conflicting information on the job, and I can tell you that an n1 block isn't going to do it, because I'm not doing it again. I'm not keen on forking 10k on a rrr block to be a gunie pig either. As for properly tuned and maintained, don't get much better than a new one. And I still killed it. I know of some companies that have done it, but they aren't too keen on telling the secrets, and that's understandable.
^^ even a brand new block and Internals can be destroyed by poor tuning/assembly/maintenance
I understand that you dont want to be forking out for a new block etc but there must of been other issues that killed your engine so quickly
Why did it let go?
From what I have seen the strongest factory block out there is the RD28 block. Which is due to all the extra ribbing it has cast into it. The factory bores are not really that much thicker/stronger like alot of people have said in the past. Ultimate budget setup would be RD block with some darton sleeves in it and grout filled to within an inch or two from the top to allow coolant around the top of the bores and access to head without too much stuffing around. That's without actually going to a full billet alloy block which is getting into serious money territory.
That's a good starting point to hold atleast 1500+ HP.
Just what sort of power/torque are you talking about here roughly?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
