This has probably been asked a million times. Is 300rwkw unreliable for a stock internal rb25. I understand that the tune and maintanance obviously plays a big part. Has anyone else had much success with this power level? And also, what do you suggest a good power level for street?
https://www.sau.com.au/forums/topic/436966-rb25-stock-internals/
You've already asked this question in your other thread. There is no definitive answer. People run 300kw on unopened motors for years. Yours could go bang after 2 days. As I said before if you are going to sell it just repair and reassemble, strip off the expensive parts and sell the lot.
If you are going to keep it do it properly - measure the bores and see if it needs a rebore or just new rings and bearings and get some decent rod bolts and balance etc. Swap the 3540 for something more suitable.
What is a good power level for the street is entirely subjective - 260kw will be pretty quick but for some 400 is not enough.
Yes it is fine especially on a street car that gets nowhere near the punishment of a track car and if on e85 it is almost bulletproof at 300, you can start looking at 350 and still be safe on e85.
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
