Hey guys,
I've got a full custom 3.5" exhaust coming from my precision turbo into a 3.5" decat pipe, into a 3.5" oval mid muffler and exiting through a 3.5" inlet and 4.5" tip cannon..
Now after putting cams in and a bigger single turbo the exhaust note has gotten louder,
I want to get rid of the rear cannon and was thinking of afew options
If anyone can advise which would be best to quieten it down please let me know
So far I looking into a Vibrant street oval muffler which is 3.5" in and out (and painted black which I like)
http://vibrantperformance.com/catalog/index.php?cPath=1022_1031_1109
Or considered running a hooker aerochamber, again 3.5" in and out, I can paint it black as I'm not a fan of shiny stainless exhausts
http://www.ebay.com.au/bhp/hooker-muffler
Would any of these be worthwhile to replace my cannon with?
https://www.sau.com.au/forums/topic/436967-gtr-rear-muffler-options/
Of the 2 choices the Vibrant. 304 stainless steel designed for noise reduction - plus looks better.
(have a mint 5zigen Jasma oval Muffler in black but alas it's 3" Michael)
What about places like HiTech in Sydney?
The Vibrant is 304 Staineless steel Painted black already :yes:
http://vibrantperformance.com/catalog/product_info.php?cPath=1022_1031_1109&products_id=1158&osCsid=99046d0a9d204006429f0988a5c39be2
Still requires modification to fit and flange :(
Edited by Sinista32
http://www.activeexhaustsystems.com.au/index.php?option=com_content&view=article&id=74&Itemid=216
I have one of these. I went from 2 hooker mufflers to one of these and it's 20db quieter and flows better
Two of the same muffler doesn't ever really work well as different designs cancel out certain frequencies so two of the same won't be much quieter at all.
I have an aero chamber and a straight through resonator and it is below legal volume.
Spoken to active exhaust systems, and there knowledge and products are far superior to the rest
Plus they just down in Wollongong so keep the money in Australia and support a small Aussie business
Win win
Ps look up "active exhaust systems" on Facebook they got some tasty pics !
Not quite right there mate,it comes down to the distance from the exhaust port to the muffler.For example if you only run say a rear resinator then at certain revs you will get that annoying drone sound as you are missing some frequencies with only having the rear one.Then go mount the same resinator/muffler in the middle of the system as well then this will help cancel out frequencies the rear one is missing.I know this is slightly of topic but with V8s N/A they quite often run small front resinators,a middle muffler and twin rear resinators,this will be about as good as it gets.The bonus with a turbo car is the turbo actually works as a noise suppressor,therefore less mufflers are normally needed to gain the same decibal reading.Of course screamer pipes change everything,lol
The one hassle with the "turbo as muffler" idea, true as it is, is that in order to get the most power out of the turbo you tend to want the biggest diameter pipework after it, which then works against silencing the noise.
Correct,thats why you want the biggest and longest ones you can fit
I manufacture AES mufflers. To make a good straight through (absorbtion) muffler you have to tick all the boxes. The perforated tube must have the correct open area ( holes /sq in. and between 3 and 3.5 mm) I wrap the perforated tube with INOX which is capable of high temps and then pack the muffler AT THE CORRECT DENSITY with either quality stranded fibreglass or GTB depending on the application. If it is a circuit racer then packed entirely with INOX. I also install an expansion joint in the perforated tube to prevent fatigue. This makes it possible , with some effort to repack the muffler if ever required giving it a second life. The biggest killer of mufflers is carbon resulting from a bad tune, too rich. These mufflers were developed on rotaries which provide the worst possible enviroment for a muffler i.e. very noisy and hot. They have a deeper , quieter sound. I am continueing r&d constantly to improve. It is all about silent high flow.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
