is one the top pic yours Leon? looks very professional ;)
im guessing the bottom pick is a PNM with the analog and N/E/S/W on the dash?
Top pic not mine, but thanks. (Mine is better, lol).
Bottom pic is from G35. A search on G35driver.com will return quite a few good ideas, but mostly rice A-pillar pods.
Make your own! NZ Performance Car P94 - Guys bought an Airwolf 3D XL 3D printer and produced a 3 gauge pod, PS pump bracket, PS reservoir bracket, circuit breaker box etc etc! (This is for their VH45DE powered Silvia).
  • 1 month later...
This was the pic I was really looking for before. It's the classy & subtle way the owner went about the whole thing that really impresses.
So ridiculous! I would love to know what is under the bonnet to warrant all that crap
Hay Leon what tablet did you use in the factory screen
Thanks in advance
Sorry, not me. My screen is still the OEM one. What pic in this thread are you looking at? Surely not the rice M35 pic I posted yesterday, lol. That one was in Japan afaik.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
