I'm going to mould a fibreglass one soon to fit 3 gauges where the factory screen and controls go. Aiming for the r34 look.
If it turns out alright I will make a few.
That's been a plan of mine for a long time, but just lack a work space to do it. I just grabbed Craig's on steering column mount though so prob won't worry about it.
  • 5 weeks later...
I will make a few. I now have to cut it out and work out how to mount it.
So far all the hard work is done. Moulding extras would be easy and would not cost much, although I had to ruined my old original stereo/screen surround to make the mould, so I would like to cover the cost of that from the first couple.
I think the question is how much would.you pay?
Tough call, I wouldn't want to offend by going too low, but no-one has a problem with you making a fair profit for your effort & getting yourself a replacement surround.
You have a market also with the V35 guys too so that may help cover cost.
Of course they will only need to mount a vacuum gauge for tip top fuel economy, & a pair of volt gauges to ensure their neons aren't drawing too much current...
  • Like 1
How about I make 5. Put them on eBay and let you guys bid on them? Lol
I have altered the mould a little bit. I was not 100% happy with the first one. Next one will be better.
Will post pics up of the next one, once its finished, including cut out and painted.
They look so awesome and I want them...but I'll never be able to check how green my leaf is again. So I'm torn.
I've got a boost gauge smashed in the drivers side dash vent hole, but soon I'll need another place to put the a/f gauge, what should I get for the 3rd pod hole?
Oil pressure or oil temp or even auto trans temp are a good idea.
If you ditch the leaf I have a new Nismo dash that would look great beside your new gauges. :P
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
