Im not sure yet. Moulding them is easy but its the triming that takes ages. Its hard to.trim them to get a perfect fit. If you are willing to trim/cut them out and paint yourself I will mould heaps and sell them for say $40 each plus postage.
And if that's the case and I make a lot more, I will need some time because I would want to make a new mould from steel.
I plan on mounting the gauges with there U clamp and then using a piece of thin steel flat bar bolted to the clamps and bent into position. I will take heaps of pics when i install mine.
Here is the first one finished and fitted. It turned out ok but not entirly happy with the position. They need to be lower and the curve isnt perfect. but i think its ok given its a home job and first attempt at plastic moulding.
I will make another mould from steel in a few weeks, and get it perfect.
  • Like 2
Looks good. Agreed ideally you would have them sit more vertical. I am very interested in the final product once you get it right. And as Dale said i m ok with doing the trim work and painting.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
