  • 1 month later...
So here is the new improved mould, made from thick body filler and aluminum tube which gives it heaps of strenght. With this mould I will be able to use it continuously be able to make heaps as the heat wont ruin it. in The pic of the painted gauge holder, the new improved one with better angle on it is the one on the right.
Will be fitting it up in the next few days.
I have plenty of time to play with it now as I have a company car for my daily ride. But may end up selling the stage :-( can't really keep 3 cars and my bike! If I get the right price that is...... Or I might just have to keep it. :-) that's what I tell the wife anyway.
  • Like 2
Pics. Now that I'm happy with it, time to get my hands on some defi gauges.
As for prices on these.
$60 each. Up to you to trim, paint and install.
You will be sold the moulded perspex as it comes out of the vacuum form.
Be warned, trimming is fiddly, you must prime with plastic primer before painting. Obviously you will need a 52mm hole saw and drill slow and careful.
To mount it I used thin fibre glass on the back around the seam.
I will need a minimum of 4 orders at a time to make it worth while.
  • Like 1
Maybe post it up on the V series section of the forum too, I'm sure there's some V35 owners that would want one.
I reckon! Imagine how hard those N/A's will go with 3 vacuum gauges!
  • Like 3
Yeah I will. But I'm assuming they would have English version with Australian tv set up and aus GPS......wouldn't they?
If so why would they want to change?
Could understand if it was all jap like ours! That's the main reason for me doing it.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
