Hi guys anyone here a wheel aligner i had my r34 done today and it's now pulling to left and the guy sez that's coz I don't have enough camber adjustment and I'll have to get adjustable upper camber arms (have coilovers btw) I thought that the castor would determine more side pull if uneven or maybe really uneven camber I don't know his castor results seemed a little off to me same as camber which were closer before he adjusted them, I got new tyres on the front if that helps it did veer of to the left slightly but not as bad as now can someone please have a look at the results and confirm if it's been done ok thank you in advanced
The biggest change is that your front and rear toe angles were well wrong before, and now they are set "approximately" right but they are wrong because overall the settings of those, the front camber and caster and how bent the chassis is are making it not want to drive straight.
Take it to a proper suspension/wheel alignment specialist (not the tyre shop) and ask them to look at it and what it needs to fix it.
Take it to someone that knows what they're doing. They screwed up the camber that badly it's as bad as the experiences I have had with "tyre shops". I've done better adjusting blindly in my garage. Also the rear toe seems to be excessive.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
