Hi guys this is just an idea at the moment not a serious plan but is it worth doing a rb25 swap into a r32 skyline. I have an rb20det at the moments which is fine for now but I was wanting to eventually get a rb25 and rebuild it and put it in my car but is it hard to do and what are some problems with doing it thanks.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/
I have had so many problems, it is so definitely not worth it. i still havent finished and ive been working on it for a while.. i changed it over caz my rb20 was hunting and i had the rb25 lying around so thought after reading it would be easy enough. I have plugs that dont fit, all the looms change. Dont reuse the rb20 loom, this does not work. I should of just fixed the rb20
I dont even want mine road registered so i havent worried about hooking up to body and making speedo or wipers work either.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7158928
We tried reusing the existing wiring and found the injectors we wired up correctly except one were the wiring colours reversed.
You lose VCT from the rb25det as the rb20 doesnt have it
The ECU fried when we tried using the rb20 ignitor box
Just whilst the engines out, change the loom straight to the Rb25det loom, injector loom, coil loom, ecu and ignitor box
youll need to figure out how to wire up the body harness and get the wipers, speedo, fuel pump etc all working.
Another issue i had was the injectors had seized from the engine sitting so long, had to hit them with 12v so they free'd up.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7158966
the wiring colours dont match between loom and 32 plug so youll need to do lots of reading and checking wiring diagrams etc for that to just "plug in". I posted asking for some help on this and even asking someone if theyd do it if i paid and got no answers so it was go through all the wires and figure how they transition however i dont want my registered so i ran an individual power line to the fuel pump and bypassed all of that.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7163041
I not being a smart ass but I did the swap in 2 weekends going from a rb20 with a broken timing belt to a running rb25 using a series 2 rb25, wiring harness and ecu.
I used all the r32 alternator, starter, power steering pump, a/c compressor, engine mounts and harmonic balancer. So it bolted back in as if it was always there then modified the r33 harness using the 32 body plugs (in the cabin) and fired it up and never had an issue, it was my daily driver and everything worked as per factory
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7163355
if i did it again i would have dropped a V8 in it (since its for drifting and would have been a lot less effort).. TBH the rb25 and rb20 are not worth doing up, youd be better spending the money on a 32 GTR.
End of the day its your money and if your up for the hassles and cost then go for it.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7167764
  • 1 month later...
Series 1, i got it running, idles a bit rough but no tune, injectors were seized and hit with 12v to free. need to hook up to ECU and tune.
I am now running all rb20 wiring with new AFM (stock, dont know if mine was causing a problem) and R33 ECU. Have the rb20 coil box still there as matches wiring.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7223070
It's my opinion some people should not got down this path, they're simple not suited to the problems you invariably come across.
Makes no difference if you're swapping a 25 in place of 20 or going for a V8, you will have some dramas along the way.
With all the info available on the net these days, one would expect a straight Rb to Rb swap to be easy but that hasn't been my experience, you need patience and some clear headed pin out ability when it comes to the wiring.
Forget an auto sparky unless you have very deep pockets. Usually you're simply paying him to learn.
You also need to sift through the mass of mis-information given on the net, a LOT is simply rubbish.
Talk to the guys who have actually done the full hands-on swap, not the keyboard heroes.
https://www.sau.com.au/forums/topic/437049-rb25det-swap/#findComment-7224143
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
