Hi Guys,
Up for sale is my 1992 R32gts-t.
I've had this car for a little over 3 years, straight off my P's, but i'm looking to move it along now that i've upgraded cars.
On the exterior, the car is in good all round nick, with a few minor dents/scratches, and the interior is also good, no cracked dash etc, and the motor is tuned by EFI on the Gold Coast and is making about 175rwkw's without skipping a beat and getting 10L/100km to a tank.
It has 97856km's on the clock, and the water pump and timing belt seem to have been replaced recently before I purchased the vehicle, but i'm unsure of the exact dates.
Modification wise, i've gone about it to improve the cars performance performance while maintaining a stock look, a few minor changes would need to be made to the engine bay and it would be completely as per stock. The car is incredibly punchy and nimble given the smaller turbo and low weight, combined with the suspension and braking work it makes the car a joy to drive on twisting roads.
Major Mods:
R33 Series 2 Turbocharger
Turbo back exhaust with hiflow Cat
ARC sidemount
Turbotech boost tee
Nistune Piggyback ECU
Bosch 040 fuel pump
Suspension/handling
R32gtr brakes, with good condition pads/rotors
Nismo shocks and springs
Whiteline adjustable sway bars
Hicas lock bar
New suspension bushings
In addition, I have some stock parts that were removed and other bits that I can throw in with the car aswell if wanted
set of GTR fuel injectors
set of original coils
original front+dump pipes
original sidemount
original turbo
set of braided brake lines
spare set of stock rims
This car is a lot of fun as it is, but it is ready for a power increase if you decided that's what you wanted to do. The car has rego on it until the 6/6/14 and I will sell it with a RWC.
I'm chasing $10000 for it with the spare parts, but come take a look and i'll consider all reasonable offers.
Contact:
Peter Logan
0467078022
rebel2_90@hotmail.com
located in Wishart, 15km's south of the Brisbane CBD
Note: I do FIFO work, however I can arrange for the car to be viewed at most times
https://www.sau.com.au/forums/topic/437074-1992-r32-gts-t-brisbane/
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
