Need this baby gone. Act fast, open to offers
Delivery: 5 days by EMS
Garrett TBP4 ~GT3576 size
Really rare Twin Scroll T3 AR.70 turbine housing
Garrett TBP4 T3 TS AR.75
Compressor Size: 6 blade 53mm/76.2mm
Turbine size: 73mm/58mm
Compressor flow: 52lbs/min (max 500hp)
100% Genuine
Journal bearing (not ball bearing!) Rebuildable. Barely noticeable spool difference when wideopen throttle compared to bb. ~300rpm max
Oil cooled centre core with 360degree thrust bearing
Capable of 400-500hp
Spool characteristics: 8psi at 2800rpm, 15psi at 3500rpm on rb25det
Price: AUD65o Delivered to your door. Turbo is over AUD900 retail
Pay via paypal
PM me for details
Open to reasonable offers
Edited by robots
AUD350 till 15th of JAN. BELOW THE LINE.
Also have one with .58AR twinscroll housing and smaller compressor. Good for 400hp.
Can do both for AUD700 shipped. Crazy price.
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
