Imm going bypass it going to the throttle and instead use it for my turbo water lines as i cant be bothered unpluging and use the line at the rear of the head lol.
So for turbo syphoning purposes i wana know which side coolant feeds from.
It hardly matters.
Pretty much what I thought, it doesnt matter at all which way it flows through the throttle body but figured he wanted to plumb something in as a water return
If you are purely asking so you can hook the throttle body coolant lines up, I wouldnt even bother. I havent had coolant lines to mine for about 4 years with no problems at all
No sub-zero temps around Mackay either Callan. Might make a difference for someone running a daily driver in the Southern climes.
Not many places in aus are going to get cold enough to need it. Obviously I wasnt suggesting it was ok in all cases but usually once the cars warm there is never going to be sub zero temps around the throttle body In aus
