Not sure if this is the right section to be asking this.
Recenlty purchased an R34 GTT, and soon after the handbrake light came on while driving around (dimmer than it is when the handbrake is on).
I did a few searches and first stop was to check the brake fluid, but it was already over the max line (see first pic). I bought a little bottle of DOT4 and put a bit extra in anyway (second pic), but the light has stayed on.
What else could the light be indicating? Could it be lit because the brake fluid is over the max level? Previous owner only recently had the brakes replaced and they still feel quite good - stronger than any other car I've owned.
Second - possibly related - problem is the boost gauge. The sender under the bonnet is unplugged (both power and pressure - there is a screw sealing the tube from the manifold) but the boost gauge changes depending on the state of the handbrake, as follows:
Handbrake on - Handbrake dash light full - Boost gauge all the way down
Handbrake off - Handbrake dash light half - Boost gauge all the way up
From memory when I test drove the car, the boost gauge was all the way down all the time and the handbrake light was not lit.
I tried reconnecting the electrical connection on the sender under the bonnet but it made no difference, I've got some vacuum hose to try reconnecting the pressure line as well, but I don't think thats going to make a difference.
There is an aftermarket head unit and I read somewhere they can tap into the handbrake signal, so is it possible this was stuffed up and is causing all the issues? I'm pretty sure it wasn't happening when I test drove the car, so why would that suddenly change? Any ideas where I should start looking?
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
