For sale are some quality parts I consider surplus after a few changes in direction....
1. GT2860-7's with 400km's travelled, 2nd hand cam (exh) broke and bent some valves, rebuilt engine to higher hp spec's than the -7's.
In excellent condition, includes garrett actuators.
Price; $1500.
2. Axxis Hero wheels, 19/9.5 at +22 offset, They have almost new(400km) 265/30/19 Kumho Ku31's , the wheel pictured has the worst rash,
The same wheels in my avatar, Selling due to finding some LMGT1's.
Price; $1500.
3. R33 GTR specific Apexi PFC with hand controller.
Price; $650.
4. Ti front pipe, unknown brand, Learnt the hard way R34 pipes are indeed longer than the R32 & 33's
Pics indicate its good condition.
Price; $500.
5. Kakimoto Hyper Fullmega N1 cat back exhaust in good condition, front section heat wrapped.
Price; $350.
6. CES dump's and matching front pipe, includes adaptors for lambda sensors.
Price; $300.
7. Jjr coil pac's, where replaced with Splitfires which didn't change the issue.
Price; $200.
8. Std R33 RB26 injectors.
Price; $200
9. Std R33 RB26 Crank balancer/pulley, has travelled 400km, upgrading to crank trigger set up.
Price; $200.
10. Chinese?? GTR hard pipe kit...silicon joiners and hose clamps included.
Price; $150
11. 3in Hi flow cat in good condition.
Price; $75
12. Have a std size R33 RB26 crank,
Good condition.
Price; $250
Misc...RB26 rod's and pistons, also a sleeved block which is cracked through to the water jackets from the head studs.
Offers considered....
Happy to post at buyers expense, pick up is fine too....
PM me on here or text to 0418630718.
Cheer's Glen.
Pm's replied...
Also have 2 intercooler's, 1 from an R33 GTR and the other from an R34 GTR, relatively good condition, pic's if your interested.
R33 int- $200
R34 int- $250
Gday...
The Ti pipe is 70x2 into 80mm, it will fit under the car no problems but is a fraction longer, off the shelf cat back systems will no longer fit without mods...
Hard pipe kit SOLD and dispatched.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
