Quality Gtr Parts Fs, Low Km -7's, 19/9.5+22 Wheels, Ti Fr Pipe, Pfc, Cat Back Exh,
For sale are some quality parts I consider surplus after a few changes in direction....
1. GT2860-7's with 400km's travelled, 2nd hand cam (exh) broke and bent some valves, rebuilt engine to higher hp spec's than the -7's.
In excellent condition, includes garrett actuators.
Price; $1500.
2. Axxis Hero wheels, 19/9.5 at +22 offset, They have almost new(400km) 265/30/19 Kumho Ku31's , the wheel pictured has the worst rash,
The same wheels in my avatar, Selling due to finding some LMGT1's.
Price; $1500.
3. R33 GTR specific Apexi PFC with hand controller.
Price; $650.
4. Ti front pipe, unknown brand, Learnt the hard way R34 pipes are indeed longer than the R32 & 33's
Pics indicate its good condition.
Price; $500.
5. Kakimoto Hyper Fullmega N1 cat back exhaust in good condition, front section heat wrapped.
Price; $350.
6. CES dump's and matching front pipe, includes adaptors for lambda sensors.
Price; $300.
7. Jjr coil pac's, where replaced with Splitfires which didn't change the issue.
Price; $200.
8. Std R33 RB26 injectors.
Price; $200
9. Std R33 RB26 Crank balancer/pulley, has travelled 400km, upgrading to crank trigger set up.
Price; $200.
10. Chinese?? GTR hard pipe kit...silicon joiners and hose clamps included.
Price; $150
11. 3in Hi flow cat in good condition.
Price; $75
12. Have a std size R33 RB26 crank,
Good condition.
Price; $250
Misc...RB26 rod's and pistons, also a sleeved block which is cracked through to the water jackets from the head studs.
Offers considered....
Happy to post at buyers expense, pick up is fine too....
PM me on here or text to 0418630718.
Cheer's Glen.
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
