!!280kw rb25det!!
iv been speaking tosome shops bout getting my car on the move the aim is hi 11sec and bout 280rwkw
there are a number of different turbos that diff. places have recomended
they are as follows
hks 2835 pro (420hp internal)
t61 inovative turbo (600hp external)
t4 garrett (600hp external)
gt30 (600hp external)
trust t67 (550hp external)
in your oppinions what willget me the best value for money
also they all used diff ecu
autronic
hks fcon
microtech ltx12
apexi p fc
what do uz recon is my best bet
the car will be on stock internals until i get some more money togeather
and what do u think bout stock mainfold
anyhelp will b great
(iv got a similar post on -drag-)
thanks
If you're looking for around 280rwkw then an HKS 3037 would do the job quite nicely and have a bit of room to play with because it's around the biggest you'll get that can still have an internal gate and save money not buying the external seperately.
Would also go with the Power FC as there are a heap of good tuners around that won't have any troubles getting that sort of power at the wheels for you.
For those kind of figures you will definitely have to look at injectors and all the other upgrades to go with it but will be able to get away with stock cams.
I've got my internals just dropped in and am running a HKS 3037 with Power FC which will hopefully dynoed on friday to see what it will make (hoping for 280 - 300rwkw). When i get my figures i'll post them so there's another comparison for you. I wouldn't be expecting your internals to last for too long with that much power if they're still stock either.
Guest INASNT
yes what he said. I am using a GT30 garrett with external gate and at 1 bar with all the other goodies except internals it makes around 280rwkw at 1 bar (low boost setting). I do notice sometimes that on the pfc you get a knock reading of around 65 when giving it a hard time at the top of 3rd gear and u get the check engine light flash. So if you dont trash it 2 much ur engine should live awhile.
Easy way to get there - buy DoughBoys car, sell your car Will save you alot of money.
Grepins 2835 makes an easy 280rwkw, with boost in quite early compared to GT30 or 3037.
INASNT, have you posted up a copy of your dyno sheet yet? if not, why not?:P
Guest INASNT
I have posted my 312rwkw run in the vic section before from autosalon dyno comp at 1.4 bar boost.
Me waits for the posts about not bothering to relocate the throttle body...
dido buy Doughboys car, it ran a 12 flat first go, and is running well under what a HKS 3040 /can produce...currently has 280rwks (about?)
If you want to run an 11sec 1/4 i wouldnt be getting a brass button puck clutch, and id be looking at putting aside some money for good mechanical diff and suspension mods
Hi docile33, suggestions follow;
*ECU
Power FC is good, allow for Z32 AFM
*Turbo
Garrtett GT3040 external gate :aroused:
*Exhaust manifold
The standard one has to go:thumbdwn:
*Cams
Tomei Pocams, work with VVT, don't need adj pulley. :)
*550cc inj and new fuel rail
OK, they will do the job :D
*044 pump
OK, plenty of capacity :(
*600x300x90 fmic
What type, B&P or T&F and what brand?
What size pipework?
*brass button clutch
Personally I wouldn't trust a single plate clutch to do an 11 in a GTST. Plus brass button centre is very agressive. I would look at an OS Giken twin plate. :aroused:
*hks / trust type r bov
Irrelevant
*dump pipe
What type, split of combined?
What diameter exhaust pipework?
*relocated throtle bory to front of plenum
Yuk, why? :spew:
*ebc
It's your money.
*later maybe forgies
If the tuning is not spot on, maybe earlier (not later) :Paranoid:
*Tyres
Nittos or Goodyear drag radials
*Suspension
Whiteline springs and Koni shocks, keep the rear spring rate low. :uh-huh:
My 20 cents worth :cheers:
 Share
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
