Looking to buy some new tread for the next track day so am selling the bits that were going to be the next mods upgrades on my car but decided to leave the car how it is with the power it is making for reliability as it's still my street car.
All parts will include delivery except the tyres happy to deliver within 10ks of Adelaide CBD though
Brand new in the box Z32 AFM plus plug, pins and rubber boot - $275
Greddy Oil Cooler with braided lines and oil filter re locator - $400
Greddy Sandwich plate brand new in the plastic, bought it to use with the existing cooler kit in order to keep my oil filter in the standard location but no longer using it. Bought from Garage 7 in Adelaide - $150
Sard 650cc injectors, bought from the post below for $600 selling for $600 delivered anywhere in AUS
http://www.skylinesaustralia.com/forums/topic/435340-vicneo-sard-650cc-injectors-new-z32-afm-other-bits/
R34 Manual surround - $50
Simex 17 inch tyres will double check the sizes but from memory are 205/50/17's, bought from a mates old man who used them for about 100k before getting wider rims. Paid $200 asking $150 NOT INCLUDING DELIVERY
65mm Autometer Oil Pressure Gauge and Sender, mint as it was used once and that’s it - $100
Dished 3 spoke suede steering wheel with Mazda horn button - $50
Exhaust technology made mid pipe for R34 GTT from turbo dump pipe to cat - $100
Open to offers as long as they are not stupid and will do better prices for packages if someone wants to take a few things
https://www.sau.com.au/forums/topic/437134-garage-sale-in-adelaide-sa/
Links to photos for those interested in the cooler, Z32 and re locator, If anyone needs any more photos of the items don't hesitate to ask and I can arrange them
http://www.use.com/supersize.pl?set=717b0a4c2c753eca0eb0
Will trade or part trade for:
A 1.5 or 2 way diff to suit ABS R34 gtt preferably with a 4.1 or 4.3 ratio
Decent grippy tyres that are streey legal so no full slicks (No rims are fine too)
Thanks
Some parts sold pending payment, still chasing a diff as I have found some tyres
Oil pressure gauge and sender now $70 dropped it getting it out the cupboard and put a dent on the face surround
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
Sorry for the late update been away for work heaps and bugger all reception.
All pics are in the links and once again open to offers on items and happy to assist with posting interstate
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
