RB25DET ENGINE BUILD PART OUT
Please note, engine was assembled and never left the engine stand before parting out. None of these parts have been run. Machine work was carried out by James Race Engines/Engine Action Flemington and can provide receipts for work.
ALL PRICES ARE SOMEWHAT NEGOTIABLE
Block
-New welch plugs
-Head surface decked square to bores
-Bores light honed(Still 86mm)
-Tomei oil restrictors installed in rear two head oil feeds
-Includes crank girdle/bolts, oil quirters, sump pan, oil pickup, AC/PS/engine mount brackets & rear main housing with brand new Rear main seal
$400
Head
-Hardness and crack tested
-Head face surfaced
-Brand new supertech bronze valve guides, Genuine nissan exhaust manifold studs, Camshaft seals & valve stem seals.
-Includes standard cams, valves, valve springs, hydraulic lifters, cam gears and VCT solenoid
$1000
Crankshaft
-Crack tested
-Grubscrew cleaned
-Checked for straightness and polished
-Wide oil pump drive collar fitted
-Includes crankshaft timing gear & crankshaft bolt
$400
Genuine Nissan Timing belt with brand new idler & tensioner pulleys(Including spring)
$150
HKS RB adjustable exhaust cam gear
$100
RB25DET intake manifold/Plenum/fuel rail
Has brand new genuine Nissan gaskets for AAC valve, throttle body, Plenum>runners and runners>head
$80
RB25DET standard used pistons & rods with new ARP rod studs
$100
Genuine Nissan RB 86mm rings(No gapping was neccessary, they are as they came from the factory)
$150
Genuine Nissan RB head bolt set
$50
RB 20/25 Flat cam covers and VCT timing cover set. Finished in wrinkle black, incudes Brand new Genuine Nissan cam cover seals and aftermarket half moon seals
$250
Nismo engine mounts for RB25DET
$150
https://www.sau.com.au/forums/topic/437153-vic-rb25det-build-part-out/
  • 3 weeks later...
  • 4 weeks later...
  • 3 weeks later...
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
